188 Diesel Crank Pulley
Lndeatr
New User
Working on an old Case 580 backhoe with a 188 Diesel. Need to get the front cover off. Cant get the crank pulley to slide off the crank. Hits the frame/radiator support. Looks as if the pulley pulled forward on the inner collar that slides onto the crank. Dont want to cut it off unless I know I can get a replacement. Any suggestions where to find parts?
It looks like the outer pulley with the pulley was pressed on an inner collar and slipped forward when I used the puller. Per case it looks like I had the wrong pulley. I found an OEM which is being shipped. Hopefully it has clearance. If not, I'll do what I have to. Big issue was to get it apart to see if we can fix it.
