I have had my vac for over 2 years. It has always worked faithfully lately. I put a spark plug tester in line. WHen the tractor would fire the light would light but that wasn't very often. I put new points and condenser in. Now it does not fire at all. THe previous owner had put in an 8v farmall battery. That made it start easy, and pretty much eliminated any overcharging by the 6v generator. I see where 12v can cook a 6v coil. Can I assume that over 2 years of use the same has happened? I know there has been a problem with new condensers, but it seems it should have fired for a little while before burning the points.
Thanks for any advice.
