Company Logo (800) 853-2651 Shop Now
Can this block be saved?
BT in NE
03-17-2020 18:19:03
It's a 1930 Case model C. What are my options? I'd like to keep the numbers matching if I could. Any ideas are welcome, thanks. BT
Third Party Image
Third Party Image
mEl
03-18-2020 16:56:22
 Re: Can this block be saved? in reply to BT in NE, 03-17-2020 18:19:03
The process involves interlacing the bolts, spacing them so you drill in the center between each of the bolts so they are both threaded then another is threaded into the new hole which has threads in the side of each previously drilled bolt so there is a solid row of new material. I hope that is a sufficient explanation, possibly the poster would show the special bolts and tooling involved, they come in kits I believe.
george md
03-18-2020 20:20:10
 Re: Can this block be saved? in reply to mEl, 03-18-2020 16:56:22
In the first photo you can see the heads of some of the plugs cut off ,but not completely ground smooth. The 2nd shows 2 of the heads lying next to the oil gallery and 1 with the head still on. once they are ground smooth ,you can drill between that row and do it again making the row solid material, then grind smooth . 3rd photo shows the plugs ground smooth. mEl did a good job of explaining the process .
I do a lot off cast iron welding ,and that is not the place for welding unless you have an oven to heat the block to at least 1000 deg f before and during the welding . Post heat to 1500 and slow cool , 1/2 hour to get down to 1200. look at the link in the first post and see some of the cast welding jobs. The reason I said use lock n stitch plugs is because the threads hooked and tend to pull the crack together rather than spread it like an iron tite plug .
Look up the website for lock n stitch and see the shape of the threads. That Ford block took about 150 plugs ,but where do you find another 427 side oi;er.
Keenserts use standard taps and they are much thicker wall than a helicoil thus spreading the load over a larger area.
george
BT in NE
03-19-2020 15:48:09
 Re: Can this block be saved? in reply to george md, 03-18-2020 20:20:10
I had considered using the plug method you suggest, but was worried that they might cause the crack to spread since it ends at the deck surface. Not sure if brazing would work either, I'm concerned about the heating process. Thanks to all for the responses. BT
george md
03-19-2020 19:29:59
 Re: Can this block be saved? in reply to BT in NE, 03-19-2020 15:48:09
BT ,
The reason I said use lock n stitch plugs is that they don't spread the
casting . the threads are at an angle to pull the crack together, the threads
pull against the head of the plug so it doesn't apply force to spread the crack.
Tapered plugs like iron tight will spread the crack.
The welding I do is with cast iron rod ( cast iron in stick form) and
oxy / acet torch.
george
BT in NE
03-20-2020 07:32:57
 Re: Can this block be saved? in reply to george md, 03-19-2020 19:29:59
Ok, I will look into them. Thanks, BT.
george md
03-17-2020 20:03:56
BT, The failure looks like the stud was put in way too tight. I fixed a MM 445 block for that reason , and a similar crack. Don't have any photos of that repair but have photos of other repairs. Lock n stitch makes the plugs that you need to repair those cracks. Remove stud and lace to the hole , bore the hole for a keensert thread repair and install. Using the same plugs ,do the outside crack.keenserts are much better for that repair that helicoil, larger and stronger. Will post a photo of a ford 427 side oiler that I did last year, it was cracked in the valley on both sides. holler if you need info.Also a link to more photos and other things.
george
Third Party Image
Beginning the lock n stitch repair
Third Party Image
It was cracked in both banks
Third Party Image
c.amick
03-18-2020 16:41:26
 Re: Can this block be saved? in reply to george md, 03-17-2020 20:03:56
What did you use to fill in between the plugs, J.B. Weld?
c.amick
03-17-2020 19:26:08
I would be tempted to grind the exterior crack out a little and weld it in a few spots and J.B. Weld the rest of the exterior crack to keep it from leaking. Probably should drill a hole at the end of the crack to keep it from traveling during welding. I'm no expert, however.
Thehickdaddy
03-17-2020 19:15:59
Brazen it up and run it. And never give it a second thought. Uncle fixed a similar crack in a 1935 L block back in the 1960's. It has been pulling glenco field cultivators and 4-16s for decades now.
I will try to post photos
casecollectorsc
03-17-2020 19:05:16
Did a C a couple years ago with that problem. Used copper coat and kept the torque lower on that bolt. No problem yet, but only gets parade duty now....
Third Party Image
Today's Featured Article - What Price Enthusiasm? - by Anthony West. Quite frankly, for some time now restorers like myself have become more and more concerned about the rapid increase in the prices of old farm machines here in England. There is now a growing market for "As found" machines. Which as machines get rarer, has found the birth of a new industry....one of the "procurement agent". These agents appropriate as much old machinery as possible then inflate prices at auctions. So at what price enthiusiasm? We are now seeing poor machines which 3 years ago ma ... [Read Article]
Latest Ad: 4- D6 cat dozers and accessories [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
