Company Logo Shop Now
TractorLinks.com
Case 430 Lift Arms Hydraulic Leak
Travwm
03-15-2020 14:00:53
I have all bolts removed from rockshaft cover and it won't come off. Any ideas?
Thanks,
Trav
Travwm
03-18-2020 05:17:01
 Re: Case 430 Lift Arms Hydraulic Leak in reply to Travwm, 03-15-2020 14:00:53
It worked well to take a really small sharp (almost flat and thin) chisel and lift the cover from the corners to loosen it from the locating pins. Then it came off no problem.
Thanks to all for your contributions!
Trav
Joe (Wa)
03-16-2020 10:44:07
I agree with Loren, the locator pins are the most likely problem. Do your prying close to the pins, definitely not on the corners of the cover.
Joe
Joe (Wa)
03-16-2020 10:43:54
Joe
Adirondack case guy
03-16-2020 09:36:26
You need to be a bit careful prying the cover loose. There are 2 dowels that center the housing, and if you get too rambunctious you can break the rockshaft housing.-----Loren
flatpkr
03-15-2020 18:37:33
If all the bolts are removed and it wonít budge the gasket has it stuck down. Work a screw driver or cold chisel around the joint, or tap with a hammer, it will come loose.
Make sure the 3 point arms are disconnected from the rock shaft. The cover is all one person wants to lift as itís heavy, some kind of lifting devise can come in handy if you donít want to strain yourself.
Jim
Travwm
03-15-2020 15:38:06
I have not removed the rockshaft or it's arms but everything else is removed. The cover won't even come loose.
-Trav
tgrasher
03-16-2020 05:12:22
 Re: Case 430 Lift Arms Hydraulic Leak in reply to Travwm, 03-15-2020 15:38:06
Try taking a sharp putty knife (one that will hold up to hammering) and start at the corners to make an opening that a screw driver or low angle chisel can get a start in. It's best if you have some sort of lift/hoist to put a slight pull on it and then to lift off as the cover weighs around 80 lbs but feels like more with the position your lifting at.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2020 Yesterday's Tractor Co.
