Case 570 Utility Tractor Gasoline Engine
Norman Sharp
New User
I have a 570 Case Tractor with 159 gas engine. It was running
fine and suddenly quit. it has spark and gasoline and turns over
good, but won't start. What could the problem be?
not much info , u talking about gas in the tank or have you checked the carb to make sure carb has gas?? how did you check spark?
have you pulled the plugs and looked at them? if you have them out squirt some gas into each cyl. and then try it. if it starts you have a carb problem like the main jet is plugged remove and clean carb.
