Company Logo Shop Now
Case 570 Utility Tractor Gasoline Engine
Norman Sharp
03-10-2020 13:02:11
I have a 570 Case Tractor with 159 gas engine. It was running
fine and suddenly quit. it has spark and gasoline and turns over
good, but won't start. What could the problem be?
rustred
03-10-2020 13:28:05
 Re: Case 570 Utility Tractor Gasoline Engine in reply to Norman Sharp, 03-10-2020 13:02:11
not much info , u talking about gas in the tank or have you checked the carb to make sure carb has gas?? how did you check spark?
Norman Sharp
03-10-2020 13:45:51
 Re: Case 570 Utility Tractor Gasoline Engine in reply to rustred, 03-10-2020 13:28:05
Getting spark at plug wires. Gasoline coming through carburetor when plug is removed.
rustred
03-10-2020 14:34:31
 Re: Case 570 Utility Tractor Gasoline Engine in reply to Norman Sharp, 03-10-2020 13:45:51
have you pulled the plugs and looked at them? if you have them out squirt some gas into each cyl. and then try it. if it starts you have a carb problem like the main jet is plugged remove and clean carb.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
Latest Ad: 560 factory lp has Schwartz wide front new seat all gauges work fast hitch 14.9 38 tires has power steering leak on return side lights work ta works as it should 2 sets rear wheel weights possible trade on other tractors 340 farmall john deeres molines can text pics [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
