Company Logo (800) 853-2651 Shop Now
430 3PTH
brian stanek
03-08-2020 20:58:12
my 430 is leaking hydraulic oil into the rear end. my manual tho not to explicit says it could be trans, seal or rock shaft return line. does that sound about rite? hope to pull the rock shaft cover tomorrow.
brian stanek
03-10-2020 09:10:25
 Re: 430 3PTH in reply to brian stanek, 03-08-2020 20:58:12
mine is like the pic. with the bushing, except for one thing. on the one in your pic they staked with a centre punch it looks like. on this one the seal is just slitely into the housing bore and a drift punch was used to peen over the edges of the housing making it impossible to remove. I am slowly trying to break it up with a chisel. it would be nice to take the housing out but as you say not advisable . thanks for the info.
brian stanek
03-09-2020 18:54:27
so everything went well as far as getting the cover off etc and pto shaft out. then I discovered a big problem. the last ---- to put a seal in got carried away with a long bar or? any he damaged the area where the seal goes in making it impossible to pull out the old one.have been using a chisel to hopefully nget it to crush enough to get it out. had a good slide hammer first but would not go by the peened edges. so far it looks like two seals facing opposite directions? what a mess
Joe (Wa)
03-09-2020 20:56:04
 Re: 430 3PTH in reply to brian stanek, 03-09-2020 18:54:27
Service manuals recommend the seal be staked. Note the dimples on the housing Pic1, that is the proper way to stake a seal with a center punch.
Third Party Image
Do not use a slide hammer to remove the seal, the seal housing is pressed moderate interference fit over the end of the transmission main drive shaft. It is no fun pressing the original seal housing back in securely so it doesn't back out down the road, best to leave it as is. The seal is double lipped and wide so it has to come off a little at a time. Use a puller like Pic2, the base should be wide enough for the base to rest on seal metal with the sharp end inside, pry a little bit all the way around until it pops loose. Third Party Image
I have only changed the seal on early 430 1960-64 which has a bushing inside the end of transmission main drive shaft as Pic1 while the 1965 and later 430 has a needle roller bearing. Which one are you working on?
Joe
brian stanek
03-09-2020 09:50:10
thanks so much for the posts. I will do that, also think at same time will check out the brakes when the oil is drained.
brian stanek
03-09-2020 08:22:40
so do you need to split the tractor to do the pto seal?
Joe (Wa)
03-09-2020 08:58:05
 Re: 430 3PTH in reply to brian stanek, 03-09-2020 08:22:40
No split to change the PTO shaft seal. Just pull the Eagle hitch cover under the seat that contains the hitch rockshaft/ piston assembly. Pic is 300 but basically the same as 430. John Saeli will have the new seal (315) 585-9826.
Joe
Third Party Image
Third Party Image
flatpkr
03-09-2020 05:44:15
I have a 1961 431 that had the exact same problem. With advise from this forum I was able to fix it myself. Apparently the two common places to leak is the PTO shaft seal and the rock shaft piston O rings. I would replace both while you have the rock shaft cover off. You need to drain the rear end and also remove the PTO unit. The PTO seal can be removed with a slide hammer. The rock shaft piston O ring replacement is obvious once the cover is off and flipped over.
I purchased the parts I needed from John Saeli. A forum member.
Jim
brian stanek
03-09-2020 03:40:52
thanks for the reply as I remember seems 3PTH stays up reasonably well on that tractor.
bradley martin
03-09-2020 01:40:22
The oil is either leaking from the 3 pt lift cylinder or migrating past the seal on the PTO driveshaft. Could be either or both. It is a common problem as age takes it toll. You can determine which is the culprit before disassembly by attaching a heavy implement to the 3pt and leave it suspended overnight. If, come morning, it has settled to the ground, the seals on the lift cylinder are kaput. If the implement is still suspended, the seal on the PTO driveshaft that runs from the clutch to the rear of the tractor is the culprit.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? " ... [Read Article]
Latest Ad: WD45 Allis Chalmers tractor that needs some reassembly or will make a great donor tractor. I have the motor torn down currently and due to life changes, I need to sell. Tractor has Firestone 16.9x28 tires. Good metal,, carb, block, manifold, head, etc. Price is negotiable for cash. Calls only 7am to [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
