Company Logo (800) 853-2651 Shop Now
Case 400 Diesel Rusty Fuel Tank
wolfie63
03-07-2020 14:14:41
Any suggestions on how to clean the rust out of my 400 Diesel Fuel Tank, its pretty rusty and when using it plugs the line so have to keep blowing it out, Just want to clean it up to eliminate that issue.
Any and all suggestions welcome
tgrasher
03-07-2020 18:05:11
 Re: Case 400 Diesel Rusty Fuel Tank in reply to wolfie63, 03-07-2020 14:14:41
Strapping to a tractor wheel works the easiest and quickest but if that's not possible, I've sat the tank on a pair of saw horses and rocked and rolled (no pun intended) the tank off and on with the muratic acid and 10 ft of chain for about an hour then rinsed. I then use a tank coat (red one works best) to seal the tank walls.I also take a piece of thin wall brass pipe (the kind that Hobby Lobby sells) that fits tightly inside the fuel port. The pipe is drilled with 1/8" holes up the 3"length of it, pinching the top to a 1/8" gap.
matthies
03-07-2020 14:41:53
If no baffle, remove tank and strap it to the rear tire of another tractor that is blocked up off the ground and run the tractor in low gear and reverse, with a 4 foot 5/16 chain and a gallon of muratic acid. Plug all the ports and reposition a few times to have chain contact all surfaces. DO OUTSIDE, as the fumes are nasty. Once clean, power wash with hot soapy water(I leave the plugs in except the fill) until the tank is full and spilling over. Then drain and dry overnight in a warm area and then rinse out with a gallon of diesel(to coat the inside) until it is put back into service. Works for me.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? " ... [Read Article]
Latest Ad: WD45 Allis Chalmers tractor that needs some reassembly or will make a great donor tractor. I have the motor torn down currently and due to life changes, I need to sell. Tractor has Firestone 16.9x28 tires. Good metal,, carb, block, manifold, head, etc. Price is negotiable for cash. Calls only 7am to [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
