Case 188 4 cyl. gas overhaul kit availability?
GM Guy
Hey all,
I have a friend that is in need of a Case 188 GAS overhaul kit.
It is in a W5 wheel loader.
He has scoured all over and all that is available is diesel kits, not gas.
If anyone out there knows of availability of a gas kit, it would be appreciated.
Thanks!
Unless someone has one sitting on the shelf, there are no production kits available. The kit pictured shows Diesel Pistons, and the small flange Diesel Sleeve needs to be modified to fit the 188 Gas. The head gasket will also be wrong. The correct head gasket for the 188 gas and 188 diesel small flange sleeve MUST come from CASE as CASE is the ONLY supplier.
I looked in an old catalog from 2015 from ctonline parts,the had a listing for the 188 gas.may or maynot have them now but would be worth a try.
Clint
Sorry misprint here is the catalog cover
I wonder if you could swap the gas engine for a diesel? I saw an add on Craigslist for a bunch of Case combine engines. One of them might have been a 188 gas.
