Case Tractors Discussion Forum |
David Brown 990 Selectamatic oil types
Author |
[Modern View] |
mbpenney
02-24-2020 05:19:55
I know this has been covered a number of times.. Have a 1968 990 selectamatic.. I understand that you use 10w-30 in engine, and tranny? Is that correct? Now for the power steering what type? Thanks I have searched the forum with no success, but wanted to make sure..
Bret4207
03-17-2020 06:37:14
Re: David Brown 990 Selectamatic oil types in reply to mbpenney, 02-24-2020 05:19:55
To the best of my knowledge there is no such thing as 80-90W hydraulic oil. Hydraulic oil usually runs several dollars less per 5 gallon bucket than diesel grade motor oil.
mbpenney
03-17-2020 04:32:47
Forgot to mention, the loader has been working fine with the 30w oil. But I can see where this would create a problem if you had any implements that did require the 80-90w Hyd oil, and when connecting them into the system. I would probably try to find a separate pump and run off PTO, or perhaps an electric clutch type, and have it run off belts from the crank pulley, with a separate tank ect.
mbpenney
03-17-2020 04:25:36
Just seen this. Yes, thanks, I knew I had seen somewhere that 10-30 was good enough. I have seen 20 oil at the store, don't think it was anymore than 10-30. Thanks Again..
Bret4207
02-25-2020 05:24:22
You don't want 80-90W in the tranny since the sump is shared with the hydraulic system. That stuff won't make it through the filter and and you'll trash your hyd pump. IIRC it takes 7 gallons of oil for the trans/hyd. You could use 10 or 20w engine oil, but it's going to cost you.
mbpenney
02-24-2020 13:40:45
Ok I think it was on another forum, that it was said that the tranny/hydraulic system works best with the 10w-30, as the 80-90 weight is to thick for them. Yes I assume Rotella 10w-40 would be better than any for the engine..
I do have the owners manual for the 990, but think it was for the later model 990
RGMartin
02-24-2020 07:57:32
They left the factory with 20W20 oil in the transmission and engine, Good luck finding any. Oils have progressed a long way since 1970. Any 15W40 diesel oil now will be better than the very best from 1970(engine).
As for the transmission... they are not picky, any clean oil of appropriate weight should be fine. I have used motor oil, it worked fine, Hytran does too.
Bret4207
02-24-2020 05:35:23
No. You want 10-30 or 10-40 diesel engine oil in the engine. You want hydraulic/transmission fluid in the tranny/hyd system, not 10-30. I use ATF in th power steering but standard power steering fluid (about 10wt) works.
Get the operators manual, it lays all this out. This link should get you to an online version of the manual. https://docs.google.com/viewer?a=v&pid=sites&srcid=ZGVmYXVsdGRvbWFpbnxkZWVyZWJyb3dufGd4OjQwYmQ2YWU0YWNmZmI0MDQ
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
A Question for Dads This recent topic from the Tractor Talk discussion board is being highlighted because it is an awesome display of the caliber of individuals that have made this site their own. The young person asking questions received positive feedback and advice from total strangers who "told it like it is" with the care many reserve for their own kids. The advice is timeless... so although it isn't necessarily antique tractor related, it will be prominently displayed in our archives to honor those who have the courage to ask and those who have the courage to respond in an honest, positive manner.
... [Read Article]
Latest Ad:
International 140 runs excellent very nice original tractor with original back tires. Always barn kept full set of cultivators. Tractor comes with original drawbar and cultivator wrench. Serial number 63788 hard to find one this nice. Delivery can be arranged if not to far out.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
