Please bare with me as I have a ? considering replacing a engine in a 2294 that got hot last fall when on a grain vac the block heater plug came loose and lost all its coolant engine got so hot it actually seized up , let it cool down and put antifreeze back in and it started back up and actually sounds OK , I am still thinking it needs work as it seemed to act like it had low compression , and was hard starting before.anyway I have a block with a good crank laying here from a 2590 that I know are good , maybe putting in new sleeves and pistons and bearings , would a person use the 2590 injector pump that was good 4 years ago or use the one off the 2294 I assume if using the 2294 pump I would also need to use the injectors from that engine too or could I use the 2590 pump and the injectors from 2294? I really think the injectors may be better out of the 2294 ? Also. Would it be possible to use the oil pump from the 2294 or because of bigger crank I assume I need to use the 2590 pump ? Thank you , I rarely post on here but read all the time , I can't believe some of the knowledge on theis forum
