Case 2090 operators seat removal from cab
andy r
I pulled all of the old cab interior out last week and was preparing to install the new when it warms up some. I think I probably should take the seat out to facilitate the installation of the new cab kit. It there an easy way to remove the seat without unbolting it? Will it slide off of the forward/backward track? If not what is the best way to take it out?
Take the seat out makes it easier and you will be able to do a better job. I have to remove them by myself , I open the rear window and set them in the opening. Secure it so it does not fall out. Then when you are finished place cardboard on the new upholstery and slide seat back in. Rod.
