Re: ‘62 Case 310 weak spark
John Saeli
02-16-2020 12:51:52
I'm confused on the wiring described above. You are definitely wired NEG ground by your battery hook up. Next, correct coil? There are 3 types of coils. 6 volt, 12 volt for use w/ external resistor and 12 volt internally resisted. Your 310 when new used a 12 volt externally resisted coil. Determine which style coil you bought, whether or not the resistor is required. Assuming the resistor IS required, it will need to be re-wired and the resistor installed on the POS side of the coil. Wire feed to resistor, then resistor to POS side of coil. If the coil is "Internally resisted", remove it from the wiring altogether. Regardless, the resistor Never goes between the coil and distributor.
