Re: ‘62 Case 310 weak spark
old
02-15-2020 15:36:39
Point gap correct??
Try the old condenser since now days it is common to get a bad new condenser.
Maybe try a hot wire from the battery to the ignition side of the coil and see if it will start that way. If it does you may have a bad wire from the ignition to the coil or from the battery to the ignition
