Mattyd2020
New User
First post people, hope I do this correctly.
I have a VAC at the farm which was the first tractor my grandfather bought to help the horses out. It has been in diminishing roles over the years at the farm and run seldom the last couple of years. Last fall I went to start it and let it run for awhile before winter and the battery was dead.
Like a fool I grabbed the jump starter and attached to the battery (while still connected to tractor) the normal way which I learned after the fact that I was wrong. The moment I did it the motor started to turn over real slow on its own and sparks flew behind the fire wall (cant remember out of where exactly).
Obviously I stopped right away and then tried to turn over with the hand crank and it still didn't sputter. I will pull the battery from the tractor, see if its still good, if not I will replace and see if I can get the tractor to turn over on its own.
Has anyone else made this same error in the past? Any words of advice on what the problem could be if a new battery doesn't fix the problem?
If I can get the tractor running again I am thinking I will restore it for my kids to enjoy as they get older.
