400 Case electronic ignition and 12 volt conversion
Isucase
New User
Have a 400 case gas that my son and I are restoring. Currently has 6 volt negative ground system. Rebuilt the carb, now getting poor spark. Would like to covert to 12 volt and electronic ignition. Can I leave the factory generator and starter on it when converting? Any pointers and suggestions are appreciated. Thanks!
Are you sure it's a 6 volt? I believe the 400 was 12 volt. If it is 6 volt you can convert to 12 volt. the starter will be fine however you will need to change the 6 volt generator to a 12 volt generator or convert to an alternator. I don't believe you can adjust the regulator on a 6 volt generator to get 12 volts.
I would get the ignition tuned to a hot spark before converting to an electronic ignition. Otherwise it is possible the spark will be just as poor with electronic ignition as it was with the points.
Your starter is just fine for 12 volts. Any competent starter/alternator shop can easily switch your generator to 12 volt, if you don't want to change to an alternator. I have had good luck switching to electronic ignition w/ a really hot coil. Gas tractors now start instantly. If you have a 6 volt system, 12 volt lights will be needed. Don
6 Volt is more than adequate to run a 400 on. Make sure you have the correct battery cables for a 6 volt system and install the biggest 6 volt battery that will fit under the gas tank. Also clean up all the wire connections that feed the ignition and put in a new set of points in the distributor. Replace the cap and rotor if it is an old set. Also make sure you have the ignition timing set correctly using a timing light to do so. I used to own a 400 that had a of M&W pistons in it. I did everything I just listed. The tractor always started no matter what time of year it was.
I am not necessarily advising but years ago I set my uncles DC regulator up to 12V, actually 14 V. It was a limited use tractor and it did not see a lot of hours. A change to 12 V will make a different tractor out of it, it will start instantly at any temperature if the starter and cables are in good condition and sized properly. I would keep cables that are sized for 6 volts. If you decide to go electronic I would advise the Pertronix Ignitor 2, It is designed to handle low ohm coils. so coil selection is not so vital. My uncle had a 400 and he was a Case dealer and that tractor had a 6 volt Exide battery for many years, If I told you how many years he got out of that battery no one would believe me so I won't post it.
Also you will need to use a more modern
set of plug wires. Electric ignitions
aren't supposed to be used with original
style wires. I would recommend making the
conversion,have had good luck with them.
Especially with todays junk points and
condensers.
