WeebleCase
New User
I'm getting a banging noise sounds rotational the faster the RPM's the more the banging, started out as a click. Today under heavy load was a banging that you could feel in the backhoe, put it in first gear low range and milked it back to the house took shifter cover off, oil is milky, placed bucket down and out triggers down ran it through all gears front and reverse, no banging, put back together drove down hill, no banging, dropped the bucket to load the tractor, loud banging is back.
Got it back to the house, took the inspection cover off by the clutch, front inspection cover from the top, the rear shifter cover again, I can't get the gear selector/ high low range cover off. I rotated the gears around I can't see any that are chipped or broken, nothing looks out of place except the milky fluid.
This is my first backhoe, I'm very new at this, any help would be very appreciated
