Kevin in Iowa
So I drug an SC home a month or so go finally getting around to making it run.. The motor was locked up, but I got it turning and cranking.. anyway I can't get any spark at
the plugs. At some point the Mag was replaced with a Delco 1111411 dist/coil. I've replaced, plugs ,wires, points condenser (gapped at .20) and coil (Internal resisted).
When I got it home the Magneto kill switch was gone, I've replaced that.. When I follow my wire from the +side of the coil it goes to the kill switch, from the other side of
the kill switch that wire goes to the AMP meter from the other side of the AMP meter it runs out to the Generator/Voltage Regulator.. So I'm wondering am I missing a wire
somewhere? Where does the coil get 12 volts. Earlier my voltmeter was showing like 6-7volts but when I crank it it shows zero, and is showing zero right now even when
not cranking. Any thoughts?
