Hydraulic breaker install on a case 580b backhoe
HEY everyone was wanting to know if anyone has installed a hydraulic breaker on a older case 580b. I am looking at a skid steer breaker attachment 450 pound hammer uses 13gpm flow was wanting to know if I could retrofit it to work for my backhoe without having issues.
We sold a lot of Ingersoll breakers new with 580CK and 580B/580C units worked very well, they have a 22 or 24 gpm pump we had a extra valve kit that came with them we installed and tied into the system
Be careful what you wish for. Had B in to work on ,it had worn a
hammer for a long time ,piston had actually swelled the cylinder
where the piston was set while hammering . Had to replace the cyl
barrel an all the extend a hoe slides ,remake some of them. Looked
a lot like the end where the packing gland screws in.
george
You are very correct they are hard on many parts pins bushing ect here the local rental store that rents Cat equipment will take a machine that has higher hours on it and put a breaker on and it stays there for five years or so then the whole machine is taken to a auction out of the area and sold,, with the breaker on it,,
