1370 shift rod
louichman
01-19-2020 20:46:09
Looking for the rod from shifter to park lever on trans, someone cut it off with a torch was the way and I got it with only half of it there.
thanks
louichman
01-21-2020 09:23:44
 Re: 1370 shift rod in reply to louichman, 01-19-2020 20:46:09
ahhhh, it has what looks to be a push button on the dash that says micro lock, the ones I used before were a knob style you had to manually pull out in the tow truck.
Case Nutty 1660
01-21-2020 10:41:25
 Re: 1370 shift rod in reply to louichman, 01-21-2020 09:23:44
Nice already one installed sweet I have a 970 with the same button,, my parking hand brake works so I never use it but it does indeed work,,
louichman
01-20-2020 19:33:24
So maybe just leave it alone and use the snow blower as a park brake :D
Case Nutty 1660
01-21-2020 05:51:09
 Re: 1370 shift rod in reply to louichman, 01-20-2020 19:33:24
Unless you want to split it and repair it which unless you do it yourself is not cheap, I would consider just adding a Mico brake lock,,
Adirondack case guy
01-20-2020 09:26:48
Well, you were looking for a rod for your 1370 and 1370Rod gave you the truth about 1370 rods. Kidding aside, I be willing to bet that the park lock was hanging up and and was cut off so someone didn't have to give the tractor a little nudge to get it out of park when on a grade.----- ----- -Loren
1370rod
01-20-2020 06:07:54
You will need to find a parted out 1570 or late model 12-1370 to get that rod. Or have someone with a tractor that has park measure the length for you then you could repair yours. My guess is the park does not work, I don't know why they would cut it off like that. Rod.
