188D FUEL lines
Does anyone know if the copper fuel line from primary filter housing to injector pump that has the rubber fitting into the compression fittings can be replaced. They wont stop leaking!
Also, on the flywheel, I only see DC not TDC with lines that are visible in the inspection hole. How many degrees does each line represent?
That tractor never had copper fuel lines on it, until a PO did some replacing. The marks/lines, should represent individual degrees.--------
--------Loren
thanks for the reply, but that didn't help me out....Im thinking that these are compression fittings that are leaking [sucking air into the injection pump] how do I fix this problem?
Get some steel tubing the right size (3/8 brake line possibly), some new sleeves for the fittings and make some new lines.
(quoted from post at 06:29:50 01/13/20)
thanks Jim, I haven't found if the fuel lines should be flared [single flare / double flare... with or without a farel or o-ring into the compression fittings. thanks Jerry
The parts book shows them as rubber sleeves. The tubing should not need a flare with those. Sometimes just changing that sleeve stops the leak, they compress and harden over time. The tubing may be deformed some where they have been riding. Does yours have the rubber sleeves or some type of metal ferrel? 9846567 is the Case part number for the 3/8 rubber sleeves they show in the fuel lines I think you are asking about.
(quoted from post at 18:23:02 01/13/20) The parts book shows them as rubber sleeves. The tubing should not need a flare with those. Sometimes just changing that sleeve stops the leak, they compress and harden over time. The tubing may be deformed some where they have been riding. Does yours have the rubber sleeves or some type of metal ferrel? 9846567 is the Case part number for the 3/8 rubber sleeves they show in the fuel lines I think you are asking about.
Jim, these lines have rubber sleeves and the sleeves are very hard and somewhat brittle.. I tried O-rings but that didn't work. I have some metal ferrels, I wonder if I should try that to stop the leak. Also on the fuel tank shut off valve, but when I ordered a new a new valve, it's been replaced to a smaller 1/4" line. That means I would have to replace the fuel line from the tank to the filters and all the hardware. hmm? thanks Jerry
(quoted from post at 01:42:17 01/14/20)
If you use metal ferrules you will need to change the fittings and lines to get the ferrules to seal properly. Have you tried getting the right sleeves from a Case dealer? Dieseltech may have them as well.
It doesn't sound right for the new valve to be 1/4" for a diesel. Did the valve come from a Case dealer? The part catalog shows the valve using the 3/8 rubber sleeves like the other fittings. If it has been discontinued you should be able to find a 3/8 NPT valve and fittings to keep the original size line, that would be my path if it were mine.
Case CNH has all the rubber sleeves for all size lines used.
Also a competent injection pump rebuilder usually has them too.
Tom
(quoted from post at 18:39:10 01/14/20) Case CNH has all the rubber sleeves for all size lines used.
Tom
Thanks Tom, my pump guy has them...but its not advised to keep the leaking copper lines, it's time to replace them with steel lines. Napa, Tractor Supply didn't have the steel lines and all connections perhaps just a new counter person! {LOL} but she didn't have the parts, so I think it's time to go somewhere else..I need them asap so mail order won't work and there isn't a dealer within 50 miles.
thanks Jerry
NAPA SHOULD have the 3/8 inch steel line, similar to brake line. It will need cut and bent to the size you need, re-using the line nuts and rubber compression sleeves on each end.
You can use NEW copper, BUT , the vibration HEAT , and nature of
copper will leak over time and wear ,. As others said it came with
steel lines,,. here is how i time the last 188 i did with ahelper ,
Pipe wrench the PTO while engaged to get to 2-6 degrees BTC .
You might have misunderstood what we are talking about. I'm not surprised TSC didn't have auto brake lines, but most auto parts stores generally have a selection of them in various sizes and lengths; standard and metric. NAPA won't have pre-bent fuel lines for your machine, if you want them pre-bent those would be Case parts. The NAPA site on line lists 3/8" steel brake lines, so any store can get it for you. Here are a couple part numbers for plain steel brake lines from the on line site: BK8131242 is 3/8" x 30" long, BK8131245 is 3/8" x 60" long. These are pre-made lines with inverted flare fittings on them. Use a tubing cutter (get a cutter if you don't have one, don't use a hacksaw) to cut the inverted flares off the line and then slide the inverted flare nuts off the tube. To do a neater job, get a tubing bender for 3/8 tubing when you get the lines. Using that bender and your tubing cutter duplicate the old lines. As Dieseltech said [u:ff43cf97c7]reuse the old fittings and nuts[/u:ff43cf97c7], you should only need new sleeves to go in the old fittings.
I did misunderstand you...I did get the right tube cut and bend the brake line, Im not sure but still can't locate the size of the secondary fuel filter bleeder that is built into the filter housing unit. I haven't found a case dealer website, perhaps someone can provide their site / phone number to avoid future case parts. This case is a 580 Construction King powered by 188 diesel. thanks Jerry
First where are you located, general area? People maybe able to give you better ideas on finding parts with that info.
Do you know where you nearest Case construction equipment dealer is located or is that what you want to know?
Do you have a parts manual? If not do you know about and use the on line parts books? Having part numbers helps with searches.
Is this picture your fuel filter set up and are you looking for item key number 20? If not post a picture of what you have.
(quoted from post at 16:04:38 01/17/20) First where are you located, general area? People maybe able to give you better ideas on finding parts with that info.
Located near Port Jervis NY, 12771. I do not have a parts catalog but I went to case construction website and the parts I tried to order are no longer available. I don't have a phone number for a dealer either. The tractor places within 30 miles of me were not helpful either. I did get the 3/8 fuel line, replaced most of it but noticed I did not have a bleeder for the secondary fuel filter but I temporarily found a 10mm x24 /3/4 " bolt to plug the bleeder hole for no..thanks Jerry
Dieseltech might have a source for the bleeder screw. If the threads are 10mm-1.5 pitch, Dorman Products shows a bleeder screw for the Duramax filter housing, part number 904-112. NAPA, or other parts store, should be able to get one of those. If the bolt threads in ok and doesn't go in deep enough to hit the filter, use a copper or nylon washer under the head of it and it should be ok.
Find the serial number for your 580 and have it with you when you check for parts. There are times it is needed.
Using the Case CE dealer finder on the parts book site and your zip code I found Hoffman International, Inc. in Marlboro, NY. You can see there are others as well in NY.
https://partstore.casece.com/us/dealer_locator.html
(quoted from post at 17:23:42 01/17/20) Dieseltech might have a source for the bleeder screw. If the threads are 10mm-1.5 pitch, Dorman Products shows a bleeder screw for the Duramax filter housing, part number 904-112. NAPA, or other parts store, should be able to get one of those. If the bolt threads in ok and doesn't go in deep enough to hit the filter, use a copper or nylon washer under the head of it and it should be ok.
Jim thanks again ...
