Company Logo Shop Now
TractorLinks.com
Re: Robert Bosche injection pump
longcases
01-13-2020 06:38:37
These are the only other numbers on the tag. EP/RSV300...1000A2B240DR. I thought it was off of a 930 but it is off of a 1030. I just like these pumps and am hoping it will work on my project other wise I will have to find something else. Thanks for your help.
Dieseltech
01-13-2020 08:29:47
 Re: Robert Bosche injection pump in reply to longcases, 01-13-2020 06:38:37
Early Case Bosch inline pumps have the tag on the back side next to the engine, just above the pump spring/tappet side cover. You have the rear governor tag numbers. The PES numbers I need are on the pump tag.
Dieseltech
01-13-2020 08:32:40
 Re: Robert Bosche injection pump in reply to Dieseltech, 01-13-2020 08:29:47
Also note, 830, 930, and 1030 use the same pump pilot plate diameter. The 70 series use a larger pilot bearing plate.
longcases
01-13-2020 12:38:51
 Re: Robert Bosche injection pump in reply to Dieseltech, 01-13-2020 08:32:40
The number is PES6A 85C420 LS2054 . There are some other ones there do you need them also?
Dieseltech
01-13-2020 13:10:03
 Re: Robert Bosche injection pump in reply to longcases, 01-13-2020 12:38:51
That's what I needed to see. The LS means the pump turns counter clockwise, same as most other CASE pumps do.
longcases
01-13-2020 16:32:06
 Re: Robert Bosche injection pump in reply to Dieseltech, 01-13-2020 13:10:03
Thanks Diesel Tech mabey I will use the CAV that came with the engine.
Dieseltech
01-13-2020 17:20:14
 Re: Robert Bosche injection pump in reply to longcases, 01-13-2020 16:32:06
What engine are you working on, and what do you want it to do? Maybe the stock pump can have some changes made..
longcases
01-14-2020 06:32:42
 Re: Robert Bosche injection pump in reply to Dieseltech, 01-13-2020 17:20:14
I bought some 5.9 cummins in various stages of disrepair and am assembling one to do a project tractor just to do it no real definite goal mostly to see if it can be done. I have some of the Case pumps around and would like to use them for something rather than let them go to waste. The engine will probly end up in a 30 or 70 series Case tractor.
Dieseltech
01-14-2020 07:41:36
 Re: Robert Bosche injection pump in reply to longcases, 01-14-2020 06:32:42
The Cummins 5.9 had several pumps available, Bosch VE and CAV DPA rotary pumps, Bosch inline A, P, and P7100 depending on power output needed. You would be better off staying with these pumps than trying to fit the older Bosch/Case pump.
longcases
01-14-2020 09:12:03
 Re: Robert Bosche injection pump in reply to Dieseltech, 01-14-2020 07:41:36
Ya I know . I just like to do what other cant or wont do. I have my own machining capabilities so doing thing outside the box is fun. And im frugal.
Dieseltech
01-14-2020 09:21:43
 Re: Robert Bosche injection pump in reply to longcases, 01-14-2020 09:12:03
Nothing wrong with liking to tinker or being frugal, I like to put together different diesel "toys" too. Most Cummins have a 20MM pump shaft drive taper, the early Case inline pumps use the smaller 17MM taper. Also the early Bosch A size pumps USUALLY pull the housing threads when the delivery valve holders are removed, that problem stopped with the D series came out with an O ring seal at the top.
longcases
01-14-2020 13:10:36
 Re: Robert Bosche injection pump in reply to Dieseltech, 01-14-2020 09:21:43
Ya I found a drive assembly from a 8011 zetor that fits on the pump so I will have to build an adapter to marry the pump to the front cover and then bore the cummins drive gear to accept the zetor drive shaft the major problem will be timing and injector lines.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
