Company Logo Shop Now
Re: 188d flywheel
mEl
01-13-2020 05:09:54
It just takes time and patience, none on here learned it all overnite, if you are using valve movement to find TDC as a newbie then you really could get confused. For your purposes if the injection pump is turning Just use the info I gave you to get to 8 degrees BTDC and check the pump for two lines lining up, as I stated before if there is only one mark, turn the engine a complete revolution and try again. If this was a running engine you will be fine, if not running because of a broken shaft or sheared key in the drive gear that's a whole different issue. Don't be concerned about asking questions, this subject comes up regularly on here.
Copyright © 1997-2020 Yesterday's Tractor Co.
