Company Logo Shop Now
TractorLinks.com
Re: 188d flywheel
mEl
01-12-2020 20:17:14
if u are on the right side looking in the hole the first set u see when rotating the way the engine runs is BTDC, the proper timing would be 8 degrees before you get to TDC, there are 10 marks ATDC and there are at least 30 before TDC. At any rate if you get TDC in the hole, then back the engine up till you are about 20 BTDC then come back to 8 then proceed with your timing, the reason for that is to get the gear slack out. If you have the flywheel clean you should see that every 5 degrees is a longer line in any case , each line is one degree. If you are removing the pump. make sure both lines are in the small timing window, if there is only one turn the engine another complete turn.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
