Owatonna flow meter parts
mEl
Location
NC PA.
Hey guys, I have a request not about Case but one of my favorite subjects, mostly it will apply to ex dealers . I need some replacement parts for an OTC Y94-A the later model is the 4221 flow meter and those two items carry the same part numbers between the two models, the 4221 is the digital version of the same flow meter, for those familiar they had a tubular metal square frame with rounded corners which I need and also I need the square instrument panel cover. Maybe someone on here has info I could use, my hope is find a dead one that could be obtained reasonably. Here is hoping you all had a great Christmas and wishing all a happy and prosperous New Year.
Mel
mEl is this the meter that needs parts? Haven't found any parts yet in a quick search for OTC Y94-A. Is this a Case p/n for the meter CAS-10280?
Joe
Exactly Joe, I came into possession of the one I used for years in a state of disrepair but serviceable with some TLC. The PNs in need of are 50960-BK2 wraparound and 60422-BL2 cover,
Joe, Case used the CAS number to designate special service tools. Not a part number in the traditional sense.
Brother works for CaseIH and told me that they send theirs in to OTC to get rebuilt. I also picked one up(the old white and blue box) but it works fine. OTC goes by SPX tools now if I remember right.
You are right about SPX and it appears that they are an arm of Bosch, I have been in touch with SPX and the tech help line took me back to OTC, and I have found out that the meter that followed the Y94-A which is what I have, the 4221 was discontinued in 2006 and seems they no longer support either one with parts.They have the lid but close to $130, but the wraparound is made of unobtainium.
One of my most favorite piece of test equipment,I use mine allot.dies yours eat the batteries at a rapid rate too?.there were a couple I ran across recently,I will check to see if they are still around
Clint
I have and use the power cord that came with it that clamp to the + battery terminal or the + wire at the starter and a ground point. If you do not have one it would not be hard to make up.
Thank YOU mEL, I bought mine off of eBay a long time ago,had no manuals or anything with it,have half heartedly looked for any manuals for it but ,well,lol.so I was unaware of external power.thank you.you learnt me again.one of these days I am going to pick yours and the other more experienced techs minds on a problem with a 1070,. But that's later lol
Clint
mEL,The part numbers listed for your flowmeter have a list of an M E L prefix,that is a bobcat predix,if you have a dealership around your area, they may have one in their piles of used equipment.juat a thought if you hadn't already tried that
Clint
mEL,I have been a mobile tech for bobcat for allot of years.one of the main reasons I have the hydraulic knowledge I have,
Clint
Clint, I worked for the same Case dealer for 52 years and my specialty was probably the 530 - 580 - 590 series backhoes clear up to the 580Ns + all the skid steers, I myself own a 1840, In my opinion one of the best skidsteers ever made regardless of the brand. On backhoes we did a T test on every new machine checking every circuit and recording it on a flow sheet and putting it in a notebook for future reference so we could compare flows at a later date, as you well know these flow testers will detect a leak as small as .5 gal. Our latest hoes were approaching 50 GPM. That added up to a lot of time turning the knob. A you well know the flow meter will help you put your finger on the problem within minutes without parts changing and guessing. On the ag tractors I usually isolate the pump and check it first as some problems can mimic a pump so it's better to look at that first.
Getting this meter up and running is more a labor of love than necessity because of the amount of time I spent with it!
mEL,The 1840 was a great unit, personally,I am dedicated to the bobcat line,but credit always goes where it's due.regardless.always been a case tractor guy,was born and raised on them,grandpa and dad had 30 series,and the new 70 series was replacing them,so those were my favorite.was too young to even remember allot of the 30.but back to the hyraulics,half an hour and an entire system is diagnosed ,as you said,without guess work,BUT,if you don't know what your seeing,it's easy to condenm major components and be very wrong.and I am still looking for parts to help you if I can,clint
Clint, I have the manuals for the unit and could send you pictures of the power cord, it is simply red and black battery charger clips and a plug to fit the front panel jack with a 6-8 ft cord.
No, tomorrow I am going to see if someone can make tight enough bends in conduit to make one, I have a friend who does custom exhaust tubing work and I am going to see if it can be done, Bending that short radius without wrinkling will be the challenge. I still need to send u pics of the aux power cord, If you have a radio store near you the plug you need is very standard and wire and clips are easy, I will try to get that sent.
Thank you for your efforts.. I got new gauges and installed them and got a new meter movement and will transfer the GPM face into the new meter movement, I will send pics soon .
I would appreciate that ,thank you.i was going to see if I could make a replacement myself,just have my shop all junked up right now with customer repairs,and haven't the room to drag out all the fun metal tools,insert the well known Tim Taylor noises here,,,,,
Clint
Mel, would you post a shot of that plug on here also. I bought one of those flow meters sans the cover several years ago and although probably have needed it never built all the hoses to go with it. Thanks Tom
Clint, standard charger red/black clips, regular wire , black but softer than extension cord wire, probably 18 ft long appx, not heavy as far as wire gauge, the circuitry is solid state, standard wall wort plug but I will measure it up when I get near my digital calipers.
mEL, how do I contact you directly, kind of new to this site and need some insight on a 580ck 188d...perhaps you can help me out. thanks Jerry
Dragged my meter off the shelf to look at the receptacle. This is a newer cheaper? version anyway it is different only uses 2 C cells no external connection. Digital Lcd. Model 4221 Revision C. So I went Otc site looking and got part # for Rail (50960BK2) and Cover (59405). A bit spendy but this place does show prices as though they may be available.http://www.ohiohydraulic.com/cgi-bi...884471a02467799ea5a8ca&search_field=59405
Thanks for the effort of posting the picture.
Must have written it with that disappearing ink. Wanted to thank you for the picture. I drug mine off the shelf and out of the box looking for the female receptacle. Nope mine is a newer cheaper 4221/revision C Has a digital readout and no fancy stuff like yours. Did come up with a link to the railing http://www.ohiohydraulic.com/store/product203375.html A bit spendy. Thanks Tom
How did you get that part number, it is correct and I would like to look at a breakdown as I need another part, please elaborate on how to search that site, that site is difficult for me to negotiate. Thank you, Mel if you would send your phone number I will call you. Thanks
Making good progress on the flow meter. had a hydraulic shop bend me tubing and I welded it up and had a new guage built, now to buy a cover or make one? Hopefully this will load right!
Well we all have our crazy little obsessions,I guard mine close.but it has certainly paid for itself well.i hope you can find a top for it.
Clint
