Company Logo Shop Now
TractorLinks.com
Re: 580C Power shuttle overhaul
mEl
01-09-2020 07:55:41
I have seen pump gears in much worse shape than that but the wear on the drive lugs is tapered and will cause rearward pressure of the gear against the pump body, is it your intention to rebuild this unit or are you are just "patching it up" then. I did these as a profession and when mine left the shop there could not be cutting corners or the next time we could not charge the customer, any advice I give you will be based on that thought process. If it were mine I would reseal the clutches, replace all the sealing rings and get the kit that has the snap rings to set up the working clearance on the forward clutch back plate,The heart of that system is the pump and I would replace it and the converter and do a complete disassembly, cleaning and resealing, there isa kit that includes all new bearings, that could be optional if all the existing ones are smooth. I have successfully squared up the drive lugs on the convert with a good flat file but would prefer that you replace it as like I mentioned before there is debris caked inside that converter that cannot be removed except at a transmission shop where they have a special converter cleaning machine. You will have to decide what kind of a job you want ultimately.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
