Case dc front hubs
Find a set of steel wheels. I sold a 53 wide front DC a few years ago with on, I know the fellow ditched them right away as the front end was way to light for any field
work. Larry
Newberry, we put the bottom of an SC front spindle assembly onto our post many years ago for pulling purposes, seems to me we had to machine the post but when we got it where we wanted it we just welded the bottom. The SC came with small hubs and pressed steel wheels as you are probably aware of.
some DC hubs are drilled for both wheels like my 48 DC is it came with steel wheels but has the three bolt pattern for the cast wheels also
All the hubs that I have that can fit both the 5 and 3 bolt wheels only fit the light spindles on the SC or the DC AWF. The ones I have will not fit the DC4 axle or the narrow front. If they were ever made I have never seen them.
I swapped my steel wheels from my DC with WAF to my S one time for a tractor pull,, so I guess I did not know there was a diff in DC4 wheels hubs,, all of my SC with WAF all have the three bolt vast wheels, I wondered why some hubs are drilled and others are not,, some day I will learn to keep my comments to myself lol thanks for the correction
