Company Logo Shop Now
TractorLinks.com
Case 2090 lights
kjibben
01-04-2020 09:01:06
Can anyone provide me with the electrical diagram for a Case 2090. It is hard to blow snow without lights
kjibben
01-05-2020 05:06:19
 Re: Case 2090 lights in reply to kjibben, 01-04-2020 09:01:06
Quoting Removed, click Modern View to seeThe plug under the alternator is good. Lights work when power applied. Going to find plug under cab. I took the dash apart to get to the resistors, etc. no problems there. When I put the dash back together the tach is not working.
I'm considering running a wire from the switch to the top work lights.
DKase
01-05-2020 07:05:59
 Re: Case 2090 lights in reply to kjibben, 01-05-2020 05:06:19
If there is power to the switch that will work. Make sure the fuse is before the switch.
DKase
01-04-2020 11:52:15
Check the plug under the cab near the steps.
097Clint
01-04-2020 11:02:24
097Clint
01-04-2020 10:58:36
Schematic
097Clint
01-04-2020 10:55:09
If you lost just front lights check the connector on the right side below the alternator may have severe corrosion.providing you don't have a blown fuse.tried to post a pic of schematic but couldn't,there is also a connector under the can that is troublesome,at least in my area.
Clint
Copyright © 1997-2020 Yesterday's Tractor Co.
