Case model 451
bsamot69
New User
Hello, I have been asked to see if it is possible to get this CASE model 451 tractor functioning. Apparently the brake system needs attention. I have not had much success finding anything about model 451. Is there another designation for this unit? Any suggestions as to where to look? Any feedback is appreciated. Thank you in advance
Might it be a 1070, 1270, or 1175 missing some of its decals?
Does it have the "451" on the black painted tin?
You are giving us the engine model/cubes. If it is naturally aspirated, it is a 1070
model tractor. If it is turboed with planetary rear axle hubs it is an 1170 or 1175.
If it is turboed and has a massive rear end with 1000 only PTO it is a 1270. As said
Case put a red decal on the black hood struts with the engines cu.in displacement,
and you have mistaken that for the model number.-----------------------Loren
Serial nr locations on the tractors that RGMartin & Loren just posted for you. Find the tractor model and serial nr top left pane.
Joe
