Company Logo Shop Now
TractorLinks.com
Diesel tech. Turbo images
1370rod
01-02-2020 12:50:38
Received the turbo for the 770, sure looks small compared to a unit off a 504. Looks like I have to do a bit of fabbing to get everything properly hooked up. This will be interesting, thanks for advise, Rod.
Adirondack case guy
01-02-2020 17:56:48
 Re: Diesel tech. Turbo images in reply to 1370rod, 01-02-2020 12:50:38
I saw Dieseltech's post earlier about the Turbo of the AC being too big, BUT when we turboed the 770s we used the OEM turbo off the 336 small journal power units which was the same as what was used to power the CASE/BELOIT skidders.. As I told you on the phone, those 267's really came alive with that setup on them and lots of low end torque. Only fabrication needed was the air intake system with extra capacity air cleaner.---------Loren
1370rod
01-02-2020 21:38:54
 Re: Diesel tech. Turbo images in reply to Adirondack case guy, 01-02-2020 17:56:48
Loren this is all new to me, so I don't what to expect. The turbo's for the 870's that I found were so expensive I just had to give this a try. My thoughts are if this is unsatisfactory for the 770 I could play with the 188 in the 570. Your job on the 430 is really nice and I would not mind trying that. Rod.
vac400
01-02-2020 17:54:30
Rod , I hope you post pictures as you go forward on this project. I am thinking I will do my 770 after I get all the farm machinery ready for 2020 season. Jerry from Ohio
Dieseltech
01-02-2020 16:18:12
It looks a bit different than the one I got, yours looks like it has a water coolant passage mine does not have. While it looks small, I'll bet it works fine since it has a waste gate. The turbo I got from Keystone for my IH 560 diesel is small too, but it works fine. MUCH better than the AC 301 I took off. While it worked OK at 2000 RPM and above, I wanted the boost to start lower in the speed range. I'll try to get some pics of the one I got tomorrow.
1370rod
01-02-2020 16:58:46
 Re: Diesel tech. Turbo images in reply to Dieseltech, 01-02-2020 16:18:12
Most of the work I do with the 770 is 16-1900 rpm so boost coming in at lower rpm’s will be a benefit. Rod.
Ande
01-02-2020 16:14:24
I have a Case NIB turbo, for a 1175 or 1270, so I assume its for a 451
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
