Company Logo Shop Now
TractorLinks.com
Re: 1030 Primer Pump Question??
Dieseltech
01-02-2020 08:30:09
I'd trash that one and use the late Bosch push type hand primer, installed on the supply pump inlet side, 2 447 010 033 assembly number like the Case 70 series use. Would be a tight fit but the late primers just push down and spring back up. Early type needed the handle unthreaded to be used.
John Saeli
01-02-2020 09:09:18
 Re: 1030 Primer Pump Question?? in reply to Dieseltech, 01-02-2020 08:30:09
I googled the number you posted, but that cartridge is the same as we stock for the '70 Series. The threads on it look to be 1/4" pipe, however the threads on the '30 series are a very fine large dia, maybe 7/8". To use the later cartridge, I'd have to change the base, and CASE does not offer a part number for it that I can find in the '70 series books. As a matter of fact, the early '70 series used the same pump as the '30 series. But still the mystery, where is a check valve? It needs to be below the pump in the horizontal line.
Dieseltech
01-02-2020 09:36:46
 Re: 1030 Primer Pump Question?? in reply to John Saeli, 01-02-2020 09:09:18
The one I'm referring to needs to go on the supply pump inlet valve next to the block, just like the 70 series as it has M16 X 1.5 thread pitch. It won't fit where the original one is. The Stanadyne/Roosa primer like AC and others use with 1/4 inch pipe fittings have built in check valves, I've never had an original 1030 primer apart.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
