Company Logo Shop Now
TractorLinks.com
Spark plug wires for Case 941
HowDoI
01-01-2020 21:44:40
Does anyone have a spark plug wire schematic for a Case 941 tractor or know where I can get one? Any help is greatly appreciated.
old
01-02-2020 15:10:54
 Re: Spark plug wires for Case 941 in reply to HowDoI, 01-01-2020 21:44:40
Most distributors can be dropped in in so many different position that even if the cap has a #1 marking ti means very little since who know what has been done to them. One needs to remove the distributor cap and watch which way the rotor turns as you turn the engine over to get #1 cylinder to TDC. Depending on how you figure out TDC will also have you with a 50/50 chance of having it there on compression but even if you have it 180 out that is not hard to fix.
DKase
01-02-2020 03:33:46
Pull one spark plug. Hold your finger over the plug hole while slowly turning the engine until you get compression. Stick something small into that cylinder and get that piston to TDC on the compression stroke. Pull the dist. cap and hook that spark plug wire to the terminal that the rotor is aimed at. Follow the firing order around the dist. cap hooking the proper wire to the proper cylinder. Firing order should be casted into the block on the dist. side. When it was new 50+ years ago the dist. most likely was set in a certain place when #1 was at TDC, but almost all of them have been pulled at some point and very few are in the original position.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
