Company Logo Shop Now
TractorLinks.com
The Hesselman Diesel
Grabatire
01-01-2020 14:51:12
Was the Hesselman engine simply a modification of Case's own engine or was it a completely different engine?
theljam
01-13-2020 21:38:07
 Re: The Hesselman Diesel in reply to Grabatire, 01-01-2020 14:51:12
theljam
01-13-2020 21:33:29
This is from the Case LH/LIH Operator's Manual.
Grabatire
01-05-2020 13:23:39
I should have paid more attention to Don L's comment wherein he states that all the parts were made by Case using Hesselmans patent. Could it be that Waukesha made the parts for Allis Chalmers, but not for Case?
I find this very interesting considering that Case drug its feet a bit when it came to recognizing that steam powered tractors were on their way out.
Don L.
01-09-2020 09:28:53
 Re: The Hesselman Diesel in reply to Grabatire, 01-05-2020 13:23:39
Each Company made there own castings.
Grabatire
01-05-2020 10:57:56
longcases, If I understand it correctly, Waukesha was licenced to use the Case block and modify it to use Waukesha parts. The compression ratio of 6:1 is even lower than some gasoline engines so I take it that by injecting the fuel, the idea was to deliver a finer mist within the combustion chamber than what a carburetor could provide. I'm puzzled as to why such a low compression ratio was used. It would seem a higher ratio would be advantageous.
Don L. Would you have some technical info that you could share?
D Case Guy
01-05-2020 19:04:04
 Re: The Hesselman Diesel in reply to Grabatire, 01-05-2020 10:57:56
If they were burning a very low octane fuel on a spark ignition engine, which this was, a low compression would probably be necessary to avoid pre-ignition. I think the low cost fuel heads on these (L's) were probably at that 6:1 or so.
Thehickdaddy
01-12-2020 16:08:37
 Re: The Hesselman Diesel in reply to D Case Guy, 01-05-2020 19:04:04
Weren't L and LA around 4 to 1 stock?
Don L.
01-05-2020 07:12:17
All Case castings, using Hesselman's patent . I never mentioned this before BUT I have a pallet of NOS parts , possibly enough to build another engine.
DKase
01-02-2020 03:35:43
Don L has one. He could answer your questions in detail.
longcases
01-01-2020 16:07:28
The Hesselman engine was not actually a diesel. It started on gas but then it had an injection pump and a magneto. Fuel was injected into the cylinder and lite with a spark. The compression ratio was 6:1. Waukesha Engine was licened to build them in the states. The engine in the L Case was a modified Case block with an entirely different head than a gas L had. They were called an oil engine because they were spark ignighted. Allis Chalmers used a lot of the Waukesha version in their construction equipment.
Jal-sd
01-01-2020 14:57:11
I think it was a diesel from Sweden, but not sure. Rusty Acre or Dutchman, what do you guys know? jal-SD
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
