1966 Case 930 intake gaskets
Sprint63
New User
I have a Case 930 gas tractor that needs intake/ exhaust gaskets and they are apparently discontinued. The Case part # is A24549. I have one and need two more. I was told that CKS042 is a replacement but it definitely is not. Is there an alternate gasket or is there someone that makes an aftermarket gasket?
Joe that is definitely it but I bought the only one that they had about 2 weeks ago. I do appreciate you checking though.
The only solution we know of is to furnish the individual round gaskets which we keep in stock, which are cheaper anyways.
My father works for a local part store that sells Fel Pro and he couldn't get this gasket. I don't know of a part store that sells Victor gaskets or I would try that. Thanks for the suggestion though.
Joe: Can't speak for Olsen's, but the Ag Kits kit is for the 930 Diesel. Will not fit the 900 as the bolt pattern is different. The manifold gaskets are the diesel gaskets. Will not fit a 251 or 377 pre 1960. Buy from someone who knows CASE.
(quoted from post at 03:16:05 12/19/19) Joe: Can't speak for Olsen's, but the Ag Kits kit is for the 930 Diesel. Will not fit the 900 as the bolt pattern is different. The manifold gaskets are the diesel gaskets. Will not fit a 251 or 377 pre 1960. Buy from someone who knows CASE.
John, I am very much aware that one kit could not work on 3 different cid engines. I was assuming the page was for 3 separate kits, specify your model.
I looked up your site first thing, see you have the 930 diesel kit, not the 377 gas.
Joe
Joe: I tell everyone to not waste their time checking our 1/2 ash website, simply call or e-mail. I went back to Ag Kits and no matter what I put in the search, gas or diesel, 4 cyl or 6cyl, pre 1960 or later, it comes back to the same 6 cyl diesel, after 1960 kit.
John, Would you be able to give me the dimensions of a gasket? All that i care about is the inside diameter of the large hole and the distance between bolt holes.
I just order and replaced a set on my 930 gas. I?ll look in the morning and see where i got them from. I ordered an entire gasket set though.
Here?s the link to the set i bought.
https://www.agkits.com/case-a377-lpg-and-gas-head-gasket-set-a189512.aspx#.Xg0zfyRMGaM
