480ck clutch
Parshooter
New User
Hello can anyone tell me how important the throwout bearing carrier sleeve is, i'm asking because i installed a new clutch and pressure plate and noticed that the throwout bearing carrier sleeve is missing, it wasn't there when i broke the tractor in half and i noticed there was some damage on the carrier assy itself, i put everything back together the way it was and the clutch pedal won't depress i think think the carrier assy might be hanging up on the pressure plate any help will be appreciated thanks.
Carrier sleeve is as important as the teeth in your mouth if you want to chew food. but most seriously it is hard read
since you say the was no bearing carrier sleeve, how can the bearing hold on to the carrier if sleeve is missing since
the bearing is fit tight on this carrier. sleeve. I do have some good parts. my e mail is [email protected]
