case 930/941 fuel tank location and photos
dwragon
can anyone provide me with some case 930/941 fuel tank location and photos, I have an LP tractor I want to convert over to gas.
On my lp 800 Case, I drilled and threaded a hole in the bottom of the lp tank. Took the relief valve out of the top and flushed with some E-85. Drilled a small hole in the relief valve for air and covered with a makeshift cap. Made a stand pipe out of copper tubing and drilled with small holes and fit in the top of a new sediment bowl assembly. Must be going on 10 years and works fine. Carburetor is off a 400 Case gas. Looks like it is lp but is running on gasoline.
