Case 1830 Fuel Pump
drpete22
New User
I have a Case 1830 skid loader (gas) that has a bad fuel pump. The Case dealer say they can no longer get a fuel pump for it. Any suggestions?
I would go buy me a low psi, 1-4 psi electric pump by pass the original one though as it can leak into the engine if its not already,(happens a lot when the diaphragm goes in them) , if you buy a higher psi model pump 6-10 psi you may and most times do have to also buy a fuel pressure regulator as they tend to push gas past the needle and seats making them run rich/flood
cnt
(quoted from post at 14:33:34 12/03/19) OK Thanks. Where would you suggest I buy one of those....would an auto parts store carry them?
The engine in the 1830 I believe was built by Renault,I do like the electric pump deal though, a good Renault dealer or a auto parts with someone other than a kid, someone older with experience maybe could track it down if you want to stay mechanical.
OK, Thanks guys. I have a buddy at a parts store that should be able to track that down. I appreciate it!
