Chuck machines case second gear
Jocco
11-24-2019 17:19:43
On my tyranny second gear was bad also the first gear pinion on the bottom shaft. All this equaled replacement. Third fourth was fine. So the conclusion it see lots of time in second.
Chuck Machinist
11-25-2019 03:44:27
 Re: Chuck machines case second gear in reply to Jocco, 11-24-2019 17:19:43
Sounds as if she may have had rear chain loose for a long time in her life.Do you recollect in the tear down if the chains rubbed the transmission? CM
Jocco
11-25-2019 03:47:36
 Re: Chuck machines case second gear in reply to Chuck Machinist, 11-25-2019 03:44:27
Chains were not to bad minor adjustment. I would say someone was rough on shifting or gear grinding.
