Company Logo Shop Now
TractorLinks.com
spec torque case 430
sb101case
11-07-2019 15:25:18
Hi, someone would have the manual shop ?and could tell me : what is the torqe spec for the nut on pto shaft. thanks
((parts#37)) ->
https://www.hoober.com/PartsDiagram
mEl
11-08-2019 05:07:11
 Re: spec torque case 430 in reply to sb101case, 11-07-2019 15:25:18
Could you also post the nut for the end of the shaft, the parts diagram shows 2 methods of fastening that nut one type has a nut then a thin locknut and the other a castle nut with a cotter pin. A picture of the whole pto assembly would be nice.
mEl
11-07-2019 16:11:53
I cannot locate the reference number you gave but if I am correct the pto shaft is supported by two Timken tapered roller bearings, if so the nut is tightened till the shaft has a slight preload when rotated and the nut secured so it cannot move, some types had castle nuts and a cotter pin and if I remember correctly maybe the nut edge staked down in a groove in the shaft on the other style. I do not think it had a torque setting, it should be an adjustment. I you could post pictures it would be helpful as I am relying on years ago memory.
sb101case
11-07-2019 16:50:24
 Re: spec torque case 430 in reply to mEl, 11-07-2019 16:11:53
Hi mEl :
https://partstore.caseih.com/us/parts-
search.html#epc::mr56607ar806013
Copyright © 1997-2020 Yesterday's Tractor Co.
