Hi all,
I suddenly can't remove the starter from my 1950 Case VAC.
I had the starter rebuilt last year and it's been working fine. I was able to remove it once earlier this year with no problem. I tried starting the tractor the other day (after fixing the fuel lines and some other misc. tasks) and it started fine and idled for a bit. So I shut the tractor off to do something else and then tried to restart a few minutes later and... nothing. No click, no hum, no whirring. I figured maybe the battery was dead, so I plugged in a remote battery charger/starter, but all it did was hum loudly when I hit the ignition. After checking the battery and starter cables, I decided to pull out the starter to make sure it was still working. That's when I realized it's stuck in the block. I can remove the mounting bolts, but the starter will not budge. No amount of prying or coaxing will make it come out. After talking with various folks, the consensus is the "bendix" (or whatever you call the little gear on the end of the starter that spins out when you power it up) is jammed against the flywheel.
Aside from prying, pulling, and gently pounding the starter, I've tried moving the flywheel so as to free up the bendix, such as trying to rock the tractor backwards while it's in reverse gear (where it's parked, I can't move it forward), but nothing has worked. A mechanic told me I can maybe use a prybar to move the flywheel, but I can't seem to find any place to access the flywheel teeth. I found a little inspection hole on the port side of the tractor, but all I see in there is smooth metal - nowhere to pry.
Any ideas on how I can free up my stuck starter?
Thanks in advance.
Thanks in advance.
