points for Racine 400
John, It's a Racine 401 that had an engine go bad and it was replaced with a power unit gas burner. Have a problem getting the right points which got me thinking. What distributer does the gas 400 have. This one has a WICO 730169. Would this be the correct dist. for the 400 gasser. For your protection since you are under impeachment inquiry I think my email is open if you feel safer that way. Can you get the points and how much. What would be the cost for an electronic ignition set up.
Thanks, Andy
I have never run across a WICO in a 400. The 400's all left the factory w/ Prestolite's, or Magnetos as far as I can tell. The Wico's didn't show up until after 1960 w/ the 730 830. I'm not finding your WICO number in the parts books, so I'd like to have a picture of the points to be sure we have the correct set for your 400.
We had a 700 with a wico, parts were always a problem so we switched it out with a prestolite from a 400. Who knows if the wico was the original one on it.
John , my 410 came with an Auto-Lite distributor .
No trouble whatsoever with it .
