singletree
Hello, I am going to have to source a new radiator for this 990 late model/1979. When I measured the core I come up with 17 1/2 width 18 1/4 height. Through the block/fins is 2 1/4 . If measuring the radiator from outside to outside the width is 18 1/2 X 25 3/4 height - that's measuring from the base of the bolt bracket to top of tank. I haven't been able to locate a replacement with those measurements. Most blocks are only 2 inches through - front to back of the fins. I'm sure some of you fellows have had to replace the original radiators. I would appreciate your input/ suggestions
and/or any related considerations. Thanks, Steve
