570 case hydraulic leak
I am loosing hydraulic fluid, it is leaking out the bottom of the bell housing at the inspection hole.
Any idea what seal is bad?
Will i have to split the tractor to repair?
THanks
John
If you're sure the leak is hydraulic fluid then you will have to split and renew the shaft seals #55 & #63 on the hydraulic pump drive shaft. Pic is a 300 just for orientation, you do not have the spring or tach drive and a different style of throw out fork.
Remove the 4 bolts on the cover and the hydraulic pump drive as depicted below comes out as a unit. Also check that bearing #57 is good or just replace with new.
Joe
https://partstore.caseih.com/us/parts search.html?csid a5aabe16445ebf64f56fddc71c257c71&sl EN&currency epc::mr50020ar691444
The cover has 3 bolts not four. There is nothing else holding the unit in there although it may take some banging/prying and bad words to break the cover gasket loose.
Joe
