Case L belt pulley dimensions
sander
New User
Friend is going to machine a belt pulley for my '29 L. Can you help with OD and width, otherwise ill have to guess.
If they are anything like the C's there could be as many as 6 different sizes and mounting options. The early C has a straight keyed shaft, and the later ones have a tapered shaft. C's had at least 3 different diameters to match the bevel gears just behind the clutch to get the standard feet per minute.
