CASE 1835B PSI Charge light
JD1958
New User
Was using loader when psi charge light came on. Engine stalled and won't restart Seemed to work fine before hand. Stuck in field now. Will this cause engine to stop and will it reset? Thanks
After sitting for 6 hours it still did not start. On a whim I moved the bucket and loader while cranking engine. Light went off and it started. Not sure what to do to keep this from happening but I will try changing filter and hydralic fluid.
