singletree
Hello, I have been working on my case/David brown hydraulic system. I couldn't get the lift arms or front end loader bucket to work . I have finally found a major part of the problem, there may be other pieces to the puzzle that are yet to be discovered. The previous owner had hyd problems , the first thing He done was change the hyd filter and fluid. That did not fix the problem. I think the next thing that was tried to fix it was to pull the two valves located just behind the control lever, thinking that valve may have dirt or other debris in it.
When the new hydraulic filter was installed , it was allowed to come free of the suction line, the filter then tilted out of line with the suction line. When the filter housing/ bowl was bolted back on to the frame, with the filter being out of proper alignment with the suction line, as the filter housing was bolted up the filter pushed the suction line up too high to pick up any hydraulic oil, thus the pump wasn't feeding any of the hydraulic components. If any of you fellows have an idea as to how I can pull ( bend ) the suction line back into place, I would appreciate your suggestions. Mr. Martin or others may have experienced this situation before and have a solution. Thank You for any help. Steve
