Check the pins that hold your 30 series draw bars on
Bruce from Can.
Lost the pin out of the draw bar on my 930 Case while spreading manure Sunday. Took the pin out of my Case 1030 today to see what I needed, and found it broken into two.
Looks like someone made that pin. I never saw one with a hole drilled in it like that. No wonder it is broken. The tab that holds the pin in is also supposed to have a bushing that slides over the bolt holding it in so the tab/pin assy can float. and not break the tab or bolt off.------------Loren
