Company Logo Shop Now
TractorLinks.com
CASE 730 CK 3 POINT
46NADER
08-13-2019 09:59:22
LOOKING FOR DIRECTION ON A 730 CK. 3 POINT ARMS WILL GO DOWN 1/2 WAY AND STOP "HARD".. LOAD/DEPTH SETTINGS MADE NO DIFFERENCE.. IT RAISES FINE AND CANCELS AT ANY PLACE YOU STOP LEVER AT.. JUST NOT HITTING THE BOTTOM.. MOST LIKELY IN DOM VALVE?? OR INTERNAL LINKAGES??
JUST BOUGHT THIS TRACTOR.. THANKS
46NADER
08-14-2019 11:36:40
 Re: CASE 730 CK 3 POINT in reply to 46NADER, 08-13-2019 09:59:22
THANKS FOR THE RESPONSE olgentdc , LOOKED CLOSER AND FOUND THE PROBLEM.. GUY BEFORE ME CHANGED HYD HOSES FROM VALVES TO OUTLETS. HE HAD 6" OF "ADAPTORS AT VALVE END THAT EXTENDED PAST UPPER DOM ARMS.. ARM CAME DOWN TO FITTINGS AND STOPPED ON TOP OF THEM.. GOOD THING I DIDNT USE THE SKIDDY TO TRY TO PUSH THEM DOWN FURTHER!!! THANKS AGAIN..
olgentdc
08-13-2019 18:24:29
They should go down lower than the drawbar by a couple in inches but not all the way to touch the ground ,,. that established ,you may have Draft o matic valve acting up. Usually they are absolutely NO GO ,your problem is out of character ... i would look real hard at every possible mechanical stop ,,a bolt head , ? a bar of steel ?
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
