HI, have a 1965 Case 530Ck that wont move. I have taken off and dissembled and cleaned the Torque Converter control valve (valve clutch petal hooks to) as it was sticking. All moving freely now and there is one washer on pressure reg spring. I also removed the valve beside it (not sure what called but can measure converter pressure at it) and cleaned.
-oil pump pressure as measured at filter is 160, this is at the low end of range 160-235.
-Clutch pressure as measure at T fitting is 0 with clutch out and 25psi with clutch pedal in.
-unhooked hose from cooler going into T filling at control valve and put in bucket, seems to be lots of oil flow.
Any ideas? Guessing bigger problems?
