David Brown 4600
Hope someone can help,looking for carb rebuilding kit for DB 4600 Has a Zenith model #34 IVN stamped on housing also stamped Brithish Made which seems to be the big problem ,no other numbers on it,Have called many dealers they tell me no longer available,But I just don't want to give up any help would greatly be appreciated Thanks Steve
We're a lonely few. Have a '68 with an Albion loader frame. While I've been told that those parts are at a CNH dealer, I've not had to hunt for carb parts. Did a quick snoop through the electic thingy and came up with Farmers Service Inc. and Paltech. Both out of Ohio. I cant help to think that if all else failed a reasonable surrogate might be in the Land Rover family as they were using similar Zeniths about the same time. What year is your 4600 Steve?
Hi Steve,
Do you still have your David Brown 4600 with the 34 IVN carb?
If so , I wonder if you could help me by taking some photos of the linkage? I have an 885G myself but something is amiss with it and I could use some help.
Sincerely,
Kip Page
(quoted from post at 12:55:20 10/17/11) Hope someone can help,looking for carb rebuilding kit for DB 4600 Has a Zenith model #34 IVN stamped on housing also stamped Brithish Made which seems to be the big problem ,no other numbers on it,Have called many dealers they tell me no longer available,But I just don't want to give up any help would greatly be appreciated Thanks Steve
